Wheel question
Verfasst: 27.02.2008, 22:29
von Janne
Anyone knows does the 215/45-17 ET35 wheels fit to standard 87´ typ44 100 if i install KAW 55/35 lowering set to it? :roll:
Verfasst: 11.02.2009, 09:14
von yvma
hi is it a fronty or a quattro??
for the front wheels its gonna be ok but for the rear?
yvma
Verfasst: 17.03.2009, 16:17
von oldsklaudidub
Should fit, but you might need some spacers up front, 5-10mm depending on how the car is sitting.
Also that tire width is fine, Ive fit 225 with slight rubbing on the front steering knuckle, nothing a 5mm cound not fix.
