Is it possible to install Autocheck with Boardcomputer?
Verfasst: 31.10.2008, 13:15
von Ignas.quattro
Hello everyone
Since my car doesn't have neither boardcomputer , nor autocheck , I thought that It would be nice to put them in my car
I know , that there are wires and connections missing , but still , is it possible to put those in my car and make them at least show something and work? I have bought another speedo with autocheck and boardcomputer for very cheap and , well , what should I know before doing anything? By the way , I have another speedo , exactly like mine , so I can do little experiments , cause , you know , don't want to experiment with mine speedo , since it works perfectly
Greetings ,
Ignas
Verfasst: 31.10.2008, 22:11
von Ignas.quattro
You see , this is the main problem , why I'm making new topics not in english section , because no one comes here
Verfasst: 31.10.2008, 22:27
von turbaxel
Ignas,
you're probably wrong
The topic is not the easiest one. Hence the armada of people, trying to answer it
Here's a link to an autotranslated asd page reg. your topic:
http://66.196.80.202/babelfish/translat ... r%25fcsten
http://audi100.selbst-doku.de/Main/Auto ... chr%fcsten ) original
Sorry for the damaged wiring diagram, though. I seems, as if KarlS. here made it a while ago. You might get the original from him...
CU
turbaxel
Verfasst: 10.11.2008, 19:49
von Ignas.quattro
thank you for this information
So I will try to get a nicely working full speedo with AC and BC and then try to do something about it
How could I contact KarlS?
Greetings
Verfasst: 10.11.2008, 20:03
von turbaxel
You're welcome, Ignas
Just send Karl a pn (personal note) within this forum.
Klick on
or the english version, then
enter 'KarlS.' (w/o the quotes) into the adress field and write him.
Verfasst: 10.11.2008, 20:34
von Ignas.quattro
I get the text "Sorry, but no such user exists." and I only find user named "Karl" and no others. Is this the right username?
By the way ,I have some problems with understanding the english "translated" text
Verfasst: 10.11.2008, 22:25
von turbaxel
Hi Ignas,
well, as I mentioned, it's only auto translated. Sometimes it works, sometimes ...
Karl would be the wrong user, you have to choose KarlS
You can however, klick on the 'find Username' button and enter Karl*, it then should bring a dropdown where you can select KarlS ;
Verfasst: 11.11.2008, 17:57
von Mike NF
Verfasst: 11.11.2008, 22:33
von Ignas.quattro
So this is how his nick looks like
Thank you very much
I wrote him a private message and we will see what happens
Verfasst: 12.11.2008, 23:49
von Mike NF
good luck
Verfasst: 13.11.2008, 00:26
von Karl S.
Hab schon nen langen Text als Antwort geschrieben, aber mein Englisch ist etwas bescheiden, hatte im Abi nur 8 Punkte. Mal sehen.
Verfasst: 13.11.2008, 16:48
von Mike NF
du hast abi??????
*uuuuuuuuundweg*
der Mike
aber im ernst: auch wenn du abi hast, bist ja deswegen nicht gleich n schlechetrer mensch *G*
Verfasst: 13.11.2008, 17:03
von Karl S.
Ätsch, selber doof!
Verfasst: 15.11.2008, 15:14
von Ignas.quattro
Here , new speedo is in place
and this connection which is empty in my car I guess is for Boardcomputer(coming from the boardcomputer and wiper lever handle)?
aaaand I don't have this one...
When I bought the speedo I also took the AC and BC connections:
And , well , there are two problems: I have BREMS LICHT and crossed bulb blinking all the time and when I reach 3000rpm the oil picture starts blinking and beeping
Re:
Verfasst: 05.06.2011, 14:45
von Snow Racer
turbaxel hat geschrieben:
I'm new here from Norway with a queastion
is it possible to get those wiring photos/diagrams in working condition?
I got "brems licht" and red warning light at 3000 rpm that needs to be sorted asap
and I'm not sure where I can get the consumption signal... I know it comes from ECU but I believe that I got it under the steering wheel where all the relays are
help wanted
Alan
Re: Re:
Verfasst: 05.06.2011, 15:55
von Bastian
Snow Racer hat geschrieben:help wanted
Hello,
Can't help you with that personally (I always make sure that my cars have the desired level of equipment coming from the factory already) , but you might want to contact Ignas (who has solved these issues) - send him a message
(click here for that). The documents were originally uploaded by
Karl S.. Just ask him if he could send them to you -
click here to send him a message.
regards,
Bastian
