200 Turbo: several electrical problems, need schematics
Verfasst: 04.11.2008, 13:28
Hello 200 collectors,
I am living in France and bought one 200 Turbo this summer (first owner registered it in february 1987; 200000 km), and could have my local VW/Audi garage replace the distribution belt (and the ignition coil and distributor that failed when they tested the engine), but they do not have genuine wheel bearings and do not want to work with generic parts. My bearings are noisy when driving straight and even more when turning, it sounds it is time to replace all of them.
Then there are minor things to repair. Would it be useful to buy the expensive official repair manual in english (found on Amazon or MSN-Shopping) ? I don't know if it deals with my 1987 model too because the title says 1989-91... I need advice to fix the following problems:
-window motor is sometimes almost stuck on driver's door, I have to stop and grab the top of the glass with my right hand to help the electric motor before the security stops it, and there are bad scratching sounds inside.
-air conditioner does not produce cool air at all. How to check the compressor ? Is there a compatible replacement gas that is more environment-friendly ?
-all lights of air control unit often go off if I use heating. It could be a bad wiring (I found several wires that have been badly hacked, and a fuse or two blown in the fuse box under the hood, in the radio bay when I installed my radio/cd unit from my previous car).
-no power in rear cigarette lighter socket despite a good fuse.
-bad electrical contact on lighting around passenger's mirror
Thanks for all help.
