A switch for headlight range control isn't working
Verfasst: 09.01.2008, 18:10
von Ignas.quattro
Hello everyone
I saw that there is an english part of this forum , but I thought that right here I may get more answers considering the amount of topics here and there
So , the problem might be funny for you , but this is one and the only switch whose light doesn't work. In the other buttons changing lights is as simple as 2X2 , but in this one... Can someone please tell me how to..?
Greetings ,
Ignas
Verfasst: 09.01.2008, 18:14
von barny
Verfasst: 09.01.2008, 18:17
von Sedl
Hi Ignas!
Take a look at those pics:
http://translate.google.com/translate?u ... e&ie=UTF-8
You have to unmount the circuit board.
Be careful, there is a small ball in there wich you might loose.
The rest should be clear
Christoph
Verfasst: 09.01.2008, 18:29
von Ignas.quattro
ok thank you so much
But when I get that red plastic of the board by "prying it off" , how will I be able to fix it where it was again?
Use glue?
Verfasst: 09.01.2008, 18:55
von Sedl
You can use glue or a soldering iron
Verfasst: 09.01.2008, 19:17
von OPA_HORCH
Its recommended to use hot melt adhesive, but any other appropriate glue may do as well. Make shure the red plastic is fixed securly, because it has to press down the potentiometer pos.5 firmly towards the board, otherwise the range control may not work. And don't lose the small steel ball pos. 8!
Regards Wolfgang
Verfasst: 09.01.2008, 21:13
von Ignas.quattro
I thank everyone for the advices
I made everything and put back to my car
At least the switch lit up
But I'm sure that it is working(still , I will check it out tomorrow) , because I put the red plastic back on its board very nicely , I mean that plastic fixed to the board by a "click" sound and it looked very steady without doing anything else. Haha and luckily I had a non-used broken DIFF button so the lamp which lights up the word DIFF was the same as the one in that headlight switch , so it fitted nicely
I also re-soldered the DIFF button picture , well , the biggest one , I don't know how it is called
so , now what is left are the window buttons , because some of them don't glow in red. How to change those? And what lights to put in those buttons? Are they the same as the one which goes to the electric sunroof button?
You know , I have this car only for a week now , this is my very first car and everything is an adventure for me
Verfasst: 09.01.2008, 21:20
von Sedl
Take a look in there, it's not very tricky at all.
Greets,
Christoph
Verfasst: 09.01.2008, 22:05
von Ignas.quattro
ok , thanks
Tomorrow if the weather is good I will try to do something
I hope it won't take much time for me
Verfasst: 10.01.2008, 15:05
von Ignas.quattro
Verfasst: 23.01.2008, 14:32
von Ignas.quattro
Hello
There seems to be a problem with that "switch for headlight range control" - on "O" the headlights go as high as possible , but when I rotate the switch to "I" they go as low as possible and so "II" and "III" are not working at all... I opened the switch again , but everything seems to be right with it... I got another switch for free and it works just fine but it has the same problem which my switch had - it doesn't light up... I'm afraid that when I resolder a light in a new switch it will break down as my first one did... What did I do wrong at first?
And I have another problem with those central console switches... When I press them It feels like their lights have bad contacts... So I borrowed few switches and put them instead on my old ones... but they "act" the same. Could there be a problem with wires coming to switches?
