Hallo audi lowers of Germany
My name is Johan and i`m from Latvia (Lettland), i hope for your little help
I`m searching for audi 200 (KG) MAC-05(a/b) wiring diagram, i just can`t find it on the web i thought, that maybe some of you does have it on your PCs or know where to find it
thanks for links, but i already have check them out - nothing useful there..
hmm..another question is the KG engine similar with the KH, which was in early 5000 tq american models.., if so -> i could use mac-07 wiring diagram, but i`m not sure about that..
no, the KG has no catalytic converter, Lambda probe (Oxygen sensor) and some other parts are different to the KH. So the wiring diagrams are different in major things.
If you find it anywhere on the net you can use JY wiring diagrams (JY=KG for Switzerland/Sweden with mechanical exhaust recirculation)
A similar engine ist the WR used in the Urquattros, but I´m not sure which ECU there was used in the WR.
