How fast will I go? Mod.200 20V
Verfasst: 05.05.2005, 09:57
von juhakill
Hallo alles! How much will be my top speed with 350-400ps(depends which chips using)?? I have org 5gear box. Should I change to 6gear box? From which model?? Bolt on? Possible speed increase??
Edit: you can answer also auf deutsch
Verfasst: 05.05.2005, 10:59
von Jürg
Hallo Juhakill
Theoretically the 3rd power of Topspeed is proportional to Max Power.
If 220 HP lead to a topspeed of 242 km/h (Topspeed of an original 220V?), then with 350 HP you should reach a topspeed of 283 km/h or with 400 HP a topspeed of 295 km/h.
As you mentioned, the gearbox ratios are important. The calculations above are only valid if yor reach the topspeed at the RPM of Max Power.
Jürg
