Audi UR/200/90
Verfasst: 27.05.2005, 08:51
i need a little help.
i just made the engine swap -> audi 200 turbo engine KG into audi 90 typ89...
flywheel is from audi 90 20V, TDC pin marks are similar with 200` flywheel..
the next thing is wiring - i have MAC-01 ECU from URQ (chipped), but it is impossible to start engine
when we drag in, engine starts immediately and everthing works fine!!!
maybe it is because that urq flywheel has two timing pins ???????
