ufo brake calipers,
Verfasst: 28.08.2005, 12:36
von robbe1960
Hello,
is it possible to get new rubbers for the ufo brake calipers, i cleaned them in with wrong cleaner and now they are swollen , almost double in size, it's the rubbers for the shaft guids, (harmonica's)
gruss
Verfasst: 28.08.2005, 14:14
von lungo
Ay Robbe,
you can get them at your local Audi-dealer.
Part-nr. is 211 611 483 cost will be about 1,10€ each.
wrong cleaner
Verfasst: 29.08.2005, 11:55
von ray
Hello,
What cleaner did you use? just in case you used common brake cleaning fluid you just have to wait an couple of days. These fluids often do not harm the material itself and they simply evaporate.
I did this with some rubber diaphragm built in a breaking fluid containment in my old Honda....first it nearly doubled size but after 4-6 days supported by sunshine and fresh air the stuff evaporated and left the rubber in fine shape.
so if you have the chance, buy some new ones..but if not, try the above.
Raymond
PS:....can't find the "ß" on your keyboard ?
..nevermind, since a couple of years "ß" is obsolete in correct german written language
wrong cleaner
Verfasst: 29.08.2005, 18:02
von robbe1960
Used a cold cleaner, wich you after the cleaning job remove with water, the rubbers where swollen, and broke in pieces.
I'ts only one caliper that has it, for the other one i was on time and cleaned the cleaner away.
gruss, jm
