es kursieren ja die Rep.leitfäden für die neueren Turbomotore
3b, ABY, AAN sind sowieso weitgehendbaugleich.
Aber gibts auch was zum MC?
Thanks für Infos
daneant
RLF hat die auch wer für den MC?
daneant
danke danke
isham kannte ich aber die links zu den techn. infos hat sich scheinbar geändert
was ist den MB für ein motor, den kenne ich nicht, die us version des MC??
oder was anderes?
hat jemand die pin belegung steuergerät des MC?
fürs MAC14 glaub ich
ansonsten hab ich schon einiges an material gefunden
thanks daneant
oder was anderes?
thanks daneant
bzgl. Mac 14 Pinout:
ECU Pin Out MAC-14
Main ECU connector pin out, 35 pins.
When the ECU is installed in the car vertically, Pin 1 is the first pin on the right, closest to passenger door, i.e. towards the rear of the vehicle. (next to the connector release tab end). Pins 2-18 follow forward on the right side row. Pin 19 is the first pin on the left, with its position shifted slightly forward of Pin 1. Pins 20-35 follow forward on the left row.
With the ECU removed from the car and looking at the ECU at the connector end, with the metal mounting tab down and to your right. The ECU connector Pin 1 is first pin on the bottom row to the left, Pins 1-18 follow on the bottom row to the right, Pin 19 is first pin on the top row to the left, Pins 19-35 follow on the top row to the right.
1. Cold Start Valve
2. Knock Sensor #2 Signal
3. Charcoal Canister Filter solenoid control signal
4. Decel Valve
5. Engine Control Lamp control (Tan connector)
6. T6F/4 Flash Code Connector W/BL
7. Tachometer
8. CIS Freq. Valve
9. Ground
10. Coolant Sensor
11. RPM Sensor signal
12. TDC Shield and ground
13. TDC Signal
14. Over temp switch
15. Knock Sensor #1 Signal
16. Knock Sensor ground/shield
17. Boost Gauge
18. Ground (O2 sensor)
19. Waste Gate solenoid control
20. Idle Switch
21. Fuel Pump relay control
22. Ignition Module control
23. Charcoal Canister shut off (small rear valve)
24. Intake Air Temp Sensor
25. Hall Effect +12V Supply
26. Full Throttle Switch
27. Hall Sensor timing signal
28. Tan diagnostic connector, upper terminal BL/Y wire
29. RPM Sensor Shield and ground.
30. O2 sensor signal
31. Blue Diagnostic Connector, upper pin Y/BK wire
32. Brake Light Switch
33. Black Diagnostic Connector, upper pin +12V BLK wire
34. Coding connector
35. +12V Ignition supply from Terminal 15
Das kommt von www.sjmautotechnik.com
Buergi
ECU Pin Out MAC-14
1. Cold Start Valve
4. Decel Valve
7. Tachometer
8. CIS Freq. Valve
9. Ground
10. Coolant Sensor
13. TDC Signal
17. Boost Gauge
20. Idle Switch
Buergi
