which shock absorbers (rear)? - audi 100 sport quattro '90
pawelec
Beitrag von pawelec »
hello! I'm from Poland. Since 2008 i have my lovely car :D Black pearl audi 100 quattro sport with 2.3 NF engine. I need some help, because i must change REAR SHOCK ABSORBERS. This model has original -20mm suspenssion low. But here i have much problems to find original absorbers. I can buy only typical absorbers to audi 100 with typical suspenssion (not -20mm).
What would i do? What kind of absorbers can be put to this car? I dont want put normally absorber without -20mm spring.
Maybe some kind of 'billstein' can be good? Please help me ;)
thanks!
Pawel
pawelec
Re: which shock absorbers (rear)? - audi 100 sport quattro '90
so now only the K.A.W. absorber will be good to 'sport (-20mm)' suspenssion?
paulfern
Beitrag von paulfern »
gen Dobre Pawel,
the 100 sport quattro uses the same suspension as the 20020v (S743 option) this is the same the Audi 20020v (S727 option) or Audi V8 with gas shocks in the rear.
The part number associated with these options above is:
Audi part number 441 513 031 B
This means all you have to do is look for the Audi V8 or 20020v rear shocks..that simple.
No garage or dealer can tell you this because the 100 sport is not known...no one really knows what this car is...only the option on the ticket in the back of the trunk (boot) will show this.
Anyway you can find these shocks just about anywhere just make sure you say it is for an Audi V8 for example..then you get the right part.
Hope this helps out.
little_e
Beitrag von little_e »
pawelec hat geschrieben:hello! I'm from Poland. Since 2008 i have my lovely car :D Black pearl audi 100 quattro sport with 2.3 NF engine. I need some help, because i must change REAR SHOCK ABSORBERS. This model has original -20mm suspenssion low. But here i have much problems to find original absorbers. I can buy only typical absorbers to audi 100 with typical suspenssion (not -20mm).
thanks!
Pawel
I replaced the original shocks on my '90 Audi 100 TQ Sport Exklusiv with Bilstein B8 Sprints. I love my Bilsteins...
pawelec
little_e, how much it cost?
