Hello everybody, I have had an accident and I have broke securing part from transmision from an Audi 100 bj 1983. (4 speeds+E speed)
Could somebody tell where I can find this spare parts 443399113 and 443399114 - ( other cars that have had use this parts)?
Thank you very much for your help. George
Hilfe, securing parts for transmision
george
DanKe Avant
I am very glad to meet you again . I almost finish my car but till now I could not find these two supports for gearbox. This numbers are printed on broken parts. the gearbox is perhaps very strange it has 4 speeds and an economic speed (no macht with 5 speeds gearbox.) I really don't know whwre I can find this spare parts and to make it is a hard job. By regards George
george
Hi George,
I checked one liste which I have, I believ you need the support part which will fix the gearbox on the left and the right side. Due to my list, this should have the nr: left 431 399 113C and right 431 399 114C!
This should the same for each 5 shift gearboxes which are use in 1983 and 1984.
For the years 85 to 87 it is the same nr.
I will send you an email with some PDF's I hope this will help.
Regards
Mathias
Regards
Mathias
Audi 100 Limo - AAH -
Gast
Thanks
Dear friend, I have found two support parts which are fixing the gearbox on the left and the right side 431 399 113 G and 431 399 114 F bur don't match. I suppose that it is possible that my supports should be from gearbox used on an Audi 100 type 43 5E * 4speed and economic speed. Are you so kind to check this?
Do you believe that it is possible to be difference between 431 399 113 G and 431 399 113 C (and also 431 399 113 F and 431 399 113 C)?
Have a good day, George.
