Wie kommt man beim NF2 an die Schrauben der Ansaugbrücke( Unterteil ) am besten ran
NF2 Ansaugbrücke
bari nf
NF2 Ansaugbrücke
Hallo Audigemeinde
? Bei mir sitzen die Bombenfest und Unterteil muss runter weil er da Falschluft zieht
.Danke für Euere gutte Tipps
robbe1960
hello,
I've the same problem, To remove the bolts the only thing i could do at this time is to remove the whole cylinder head. Also the screws from exhoust manifold don't look like screws anymore, rusted pieces of iron.
But i decided then to do a complete overhoul of the cylinder hesd, now valve guides, new seals for the valves and hydroulic valve lifters.
A lot of work, but then everything is back ok.
gruss, jm
gruss, jm
