TACHO defect
The_saint
TACHO defect
Beitrag von The_saint »
my tacho works good but both the FIS and the autocheck don't work, what can be the problem? all connectors are connected... it's been this way since I've bought the car! :evil:
VW Passat 3BG 1.9 TDI Highline
AUDI 200 20v quattro
Ignas.quattro
Beitrag von Ignas.quattro »
Hello.
So as I understand , both - autocheck and boardcomputer don't work? I guess my friend had the same problem when he bought his 200 20v. I'll try to ask him ;)
The_saint
Ignas.quattro hat geschrieben:Hello.
yes you understand correctly, thanks a lot maybe it could be the answer to my problem!!! :danke: :danke:
Ignas.quattro
Ok , so he told me that the resistor(in the pics) was not working(burnt) and the condenser was dried out or something. Here they are in the pics(sorry for the quality , weren't taken by me)
http://domas.hard.lt/Audi_200/suo%20ir% ... %20004.jpg
http://domas.hard.lt/Audi_200/suo%20ir% ... %20005.jpg
The_saint
Ignas.quattro hat geschrieben:Ok , so he told me that the resistor(in the pics) was not working(burnt) and the condenser was dried out or something. Here they are in the pics(sorry for the quality , weren't taken by me)
ok thanks I will look into that, I'm not that good with electronics both I hope my collegues can help me out!!
Gerhard
Site Admin
Site Admin
Porsche 924 Bj 1984
Audi 80 GTE BJ 86
Beitrag von Gerhard »
Hello,
the shown source of defect is only one possible cause.
Currently I have a tacho in repair, which has definitively a problem on the main pcb.
If I find the error, I will inform you.
best regards
Gerhard :)
The_saint
thanks a lot everybody...
but if I understand correctly there are multiple causes for this defect?
isn't better to find a good working tacho or is repairing the best option?
Gerhard
Site Admin
Site Admin
Porsche 924 Bj 1984
Audi 80 GTE BJ 86
The_saint hat geschrieben:but if I understand correctly there are multiple causes for this defect?
Yes!
* resistor / condenser on AC PCB
* broken soldering general (problems eg Speedometer, glowing controllights)
* only BC without function can be a defect of voltage regulator
* undefined error of main PCB (I´m searching for a solution)
All old tacho can have problems with soldering or defect condenser. So there is no guarantee that the "new" tacho works for a long time.
In my opinion it is better to repair the own tacho.
greetings
Gerhard
